Taking Apart Vespa Grande Forks
Chris Harrington /
Has anyone separated the fork legs from the fork tubes on Vespa Grande forks? I don't see how to get them apart. Any help is greatly appreciated.
Re: Taking Apart Vespa Grande Forks
look inside the bottom leg there's am allen screw you need to open and then just pull off the leg
Chris Harrington /
No externally accessible allen screws on Grande forks. Anyone else??
campeona del mundo /
bump, also looking for info on this. Also, are grande forks are hydraulic, no? so i should fill up the legs with fork oil through the bolts on the top, right?
Chris Harrington /
Grande forks are NOT hydraulic. Don't fill them with oil!!
i knew it! i had like three people tell me they are
I just tore a set of those apart... Just turn the legs. The spring ends are the attachment points.
Like slinker said, they un screw. Takes amout 1 1/2 turns
