Peugeot 103 Belt Part Numbers
I've been trying to crawl google search results for 20 minutes and still can't find the post. I swore I saw once someone posting the various (autozone, napa, advance) car parts store's internal part numbers for Peuoeot 103 compatible belts. Anyone have the thread bookmarked or have the part numbers written down?
Re: Peugeot 103 Belt Part Numbers
Bump?
BUMP! Who's gottem!
Tim Sandberg /
Gates AX32 sucka!
I use the old belt from a small swamp cooler. Serious, these green belts are more fabric than rubber and last 10 times longer than toothed automotive styles. Only draw back is the only come in 1 inch length incriments, where automotive apps come in 5/8 lenght incriments for a more precise fit.
But these belts with the more organic composition grip like you've never seen. If your into grip that is. Some guys like a little slip.
I recommend this Napa 4L340 W for pugs with stock variator and stock spring configuration.
^That's a what I use. No problems here.
Great, I'm not alone. I thought I was missing somthing
I just searched Peugeot 103 belt and found this thread. My belt ate shit right in front of a Napa and a 30 second Google search unveiled this jewl.
Miracle.
Ok Ok ok..
What's a good P/N for.........
103 with a Variotop.
I'm at a loss for like 3 years.....on this...every single belt leads to MADNESS..
Who has the magic Variotop recipe....ARRRGGHH.
AX32 and BX32 work great for me.
M∆®†Y Køk€š /
Bump, I've been running the 4L340W for a while now and it's been good, but I wanted to test out the AX32 and BX32. Here's a comparison of their sizes...
I think I like the AX32 the best, just slightly wider than the 4L340W rides a little higher so I get a little bit more top end. I'm running a motobecane pulley and the BX just seems too wide for my liking it barely fits in the pulley groove. Seems to fit better in a doppler clutch pulley, but the bike that's going on isn't finished yet.
M∆®†Y Køk€š /
ok I just did a blog post on this here...
http://martysgarage.info/2014/04/peugeot-103-belt-part-numbers-and-comparison/
so I'm just going to copy/paste it over
It basically breaks down like this. The v-belt and wrapped v-belt are basicly the same size and shape. They have a narrower taper when compared to the other two cogged belts. A wrapped belt has a stronger tensile strength, doesn’t wear as fast, resists the elements better, can be a little spendier and isn’t as flexible as it’s non-wrapped counterpart.
The cogged v belts are better suited for going around small pulleys(your variator) and dissipate heat better. The part numbers that will work on a peugeot also have a wider taper this causes them to ride higher on the variator giving you more top end power, but losing some low end.
The wider cogged v-belt the BX32 seemed way to wide for me, but I’ve read that it might be necessary to run one if you’re running a malossi varplus. I don’t run one so I can’t confirm that.
V-Belt
Outside Circumference: 863.6 mm or 34 in
Top Width: 12.7 mm or 0.5 in
Thick: 7.14 mm or 0.281 in
4L340
CHRYSLER – B13315A
CHRYSLER – B13321
CHRYSLER – B4L340
CHRYSLER – BH19A
DODGE – 108018
FORD – D005350
FORD – D7TE8620BA
GM – 5110025
GM – 532234
GATES – 2340
GATES – 4L340
GATES – 6J23
GATES – 8254
DAYCO – 1M034
DAYCO – 3173
DAYCO – 422432
DAYCO – 422725
DAYCO – 423690
DAYCO – 423966
DAYCO – 424247
DAYCO – 48718
DAYCO – 48719
DAYCO – 49599
DAYCO – 4L340
DAYCO – 51958
DAYCO – 51959
DAYCO – 54050
DAYCO – 55671
DAYCO – 58713
DAYCO – V671MP
OPTIBELT – 4L340
WHITE MOTOR – 10A16536
RELIANCE – 108018
GOODYEAR – 1059H
GOODYEAR – 13H321
GOODYEAR – 13T321
GOODYEAR – 4L340
GOODYEAR – 74340
GOODYEAR – FA34
MOTORCRAFT – JA317R
MOTORCRAFT – JA321R
MOTORCRAFT – JJ323
PIRELLI – 4L340
CASE IH – H312751
MASSEY FERGUSON – 1023435M1
CUMMINS – 3807705
EATON – 2053048
ACDelco – 4933382
ACDelco – 5043686
BANDO – 4L340
DEERE JOHN – AP10552
NAPA – 358
NAPA – 4L340
NSN – 3030004010524
NSN – 3030005284269
NSN – 30305284269
NSN – 392424L340
NSN – MS392424L340
SEARS – 52918
SEARS – 54185
SEARS – X1451
Metric Standard – 12R865
Metric Standard – 13R865
Metric Standard – 8X340
Industry Standard – 4L340
Industry Standard – 8X339
Industry Standard – 8X340
Durkee-Atwood – 13302
Durkee-Atwood – 4L340
JASON – 4L340
UNIROYAL – 4L340
UNIROYAL – 842
UNIROYAL – 884
UNIROYAL – 896
GOODRICH – 1340
GOODRICH – 4L340
GOODRICH – 73
BROWNING – 1320
General Electric – C4A178
General Electric – C4A179
General Electric – K5705475AD10
General Electric – K5705475AD11
General Electric – K5705475AG15
General Electric – K5705475AJ7
General Electric – K5705475AN7
General Electric – K5705475AN8
General Electric – K810236360
General Electric – K810236361
General Electric – KK5705475AR49
General Electric – W1175
THERMOID – 4L340
THERMOID – V365
THERMOID – V375
PIX Belts – 4L340
ATLAS TOOL – A15390
FIRESTONE – 12320
FIRESTONE – 1716
FIRESTONE – 32013
FIRESTONE – 3J412
FIRESTONE – 3J69
FIRESTONE – W708
Gardner-Denver – 13C47
DUNLOP – 4L340
Wrapped V-Belt
4L340W
GATES – 6834
DAYCO – L434
DAYCO – P434
DAYCO – 420311
Durkee-Atwood – 48340
WHITE MOTOR – 320011738
WHITE MOTOR – 320020028
GOODYEAR – 48340
GOODYEAR – 84340
ALLIS-CHALMERS – 667980
ALLIS-CHALMERS – 70667980
PIRELLI – 48X340
CASE IH – H434143
CUMMINS – 3808685
ALLIS-CHALMERS – 0667980
ALLIS-CHALMERS – 121398
ALLIS-CHALMERS – 164146
ALLIS-CHALMERS – 174883
Metric Standard – 12RL865
Metric Standard – 13RL865
THERMOID – 4H340
PIX Belts – A32K
Western Auto – 7540165
Durkee-Atwood – XDV48340
JASON – MXV4340
GM – 3916834
DEERE JOHN – M77167
GATES – 8J15
CARQUEST – 6834
Cogged V-Belt
Outside Circumference: 871.22 mm or 34.3 in
Inside Circumference: 812.8 mm or 32 in
Thick: 8.74 mm or 0.344 in
AX32
13XC865
Wider Cogged V-Belt
Outside Circumference: 883.92 mm or 34.8 in
Top Width: 16.66 mm or 0.656 in
Thick: 11.13 mm or 0.438 in
BX32
put that in the wiki.
Brent Bublitz /
Done. Linked to his post.
jOHNNY d0UBE Wrote:
> Ok Ok ok..
Peugeot 103 with Variotop variator belt info
https://www.mopedarmy.com/forums/read.php?7,3069361,3104649
not a Baron Asshole /
That link doesnt help for PUG, those are for moby. Malossi still makes the correct belt(for pug, 61 7219) to use with ther variotop and its listed as 38 degrees. VERY close to most v-belts that are 40 degrees. Some belts listed in that link are the wrong length(moby) and 30 degrees! I have these to try soon and will report.
If anyone has tried these with a clutch pulley chime in.
