Toothed v.s. Non-Toothed Belt
Chris Harrington /
Is there any advantage to using a toothed belt over a non-toothed belt on a Vespa Grande? The toothed version is about $16 at Graingers and a non-toothed belt is about $8 at Westlake. I want to replace my 30 year old Pirelli original and would be grateful for any input.
Re: Toothed v.s. Non-Toothed Belt
The toothed belts seem to wear out quicker.
Sometimes the cheaper belts are softer and grip better, at the expense of wear.
I'm wondering if the stock belt was cogged (toothed) or not. From what I've heard they will handle more torque, however you don't have a whole lot with 50cc's.
I know on lawn mowers they are a big no no, but I've seen lots of mopeds with them. If the standard belt has worked well so far take the cheap route and the reliable one.
Chris Harrington /
Thanks for the good advice. Anyone else?
