if your magneto is spinning slow, i can think of two possible problems.
tighten your clutch cable. if its not getting enough pull, your clutch may not be engaging.
i'm not sure about the HPI, actually this is probably wrong, because i'm pretty sure there isn't a woodruff key in the HPI. but if it's misaligned, your timing is going to be way off. maybe your timing or your magneto is off.
