minarelli V1 piston
I am replaceing the piston in my minarelli V1. can anyone tell me if the arrow on the piston goes to the exhaust port or the intake port. I cleaned the carbon from the old piston but cant see an arrow.also my manual says i can compress the new rings by hand to get them in the cyclinder. is this true? i dont want to break them. thanks for any info or tips you might have on this.
Re: minarelli V1 piston
arrow usually points to forward or exhaust.
Larry Cruse /
thanks Gabby, I thought that was right but was not sure. I have had a time with this determining what size my oiston was. I dont understand why minarelli would make a 38.7mm along with a 38.8 mmhe same engine. when you convert that to inches you are talking about 0.002 in difference between the two. Crazzzzy. Thanks again for your help.
Hi
How did you work out what was needed? I have the manual and can see almost a dozen standard and oversize rings available and I have no idea which I need?
I'm might be doing this soon as well, how did you figure your piston size?
