Did you really solve the battery connection problem correctly?
My point is that there are two Black/Red wires that must be spliced together (if you don't have the correct battery connector). If these aren't spliced then the ignition won't work.
You should have a red that comes into the battery compartment that eventually goes to the battery (should be through a fuse if you have one). The green goes to the battery.
