Re: Tomos Sprint A35 fuel line crimping
Don Pflueger /
i've never had a problem with the line being long. it helps eliminate tight curves that will cause acrimp. it's a gravity feed system, so as long as the fuel line does not drop lower than the float bowl you're ok.
