Re: Anyone taken apart a puch maxi speedometer?
madisonmed /
Yup, should be pretty easy. Look through the hole in the plastic where the speedo cable goes in. You will see a nut going around where the speedo cable threads on. Get a needle nose in there and take that off. then the speedo should slip out of that housing. Then carefully pry the chrome bezel off (bend it as little as you have to cuz you need to put it back on). Pull that off and then you can take the glass off and pull the guts out. Not much to the speedo, Just bend the needle back and if you want you can lube the bearing.
