no spark for 2001 garelli supersport
i cant seem to get a apark, and ideas? ways to bypass something????
Re: no spark for 2001 garelli supersport
Check to make sure there are no cut wires anywhere then replace the plug, next the plug wire, next the coil and so on. The easiest way is to trouble shoot an electrical problem if nothing is apperant is to start at one end and change the parts with known goods one by one.
Check your bulbs (brake light in particular) and connections. You know about the brake light bulb "safety feature," yes?
Oops. forgot that only happens when you squeeze the brake levers.
2001,garelli??WTF?
