I don't have the puller to get the front
clutch off so I can replace the belt. How can I get it off?
(asking for a friend)
It doesnt require a puller.
1. Take the pipe off from the cylinder.
2. Remove the starter arm.
3. Slip the belt off the big pulley
4. Take off the clutch nut. A piston stop or magneto holder helps.
5. Take off the clutch
WORD
Thanks
To make a puller for this clutch, start with a rear stub axle off an 85 to 99 VW Golf or jetta (stock only) other rear v-dub stubs work. it is basically a 16 mm stub with a pitch of 1. drill the tip ina press to tap for a 12 mm bolt of whatever pitch you can get a tap and bolt. point te tip of the bolt, cut the tip of the threaded axle offf about an inch and a half and I bet you can guess the rest
