Peugeot 103 Seals
Can anyone tell me where I can get new crank seals for my Peugeot 103? I think I may need some clutch parts also. Are there some rubber dampers in the section with the levers?
Cast off your chains
Use those subject lines well /
Re: Cast off your chains
Mike McScoutington /
Quarterkick.com has the seals. They might be able to get you other stuff you need.
Thanks. I ordered the seals. I hope this will fix the idle.
