puch x50 gear/clutch oil
i have recently purchased a puch x50-3 speed manual which is 2stoke and is a 1981 model.
i am wanting to change the oil as when the engine is running it runs great in nuetral but when you pull the clutch in it wants to stall as the revs start to drop quite suddenly.
the bike can be kept running by revving it but i was told it has been stood for 15 years so i feel the clutch plates may be stuck together so i wasnted to freshen up the clutch with some new oil and see if that did the trick or if anyone has any other ideas please help, though i would still like to know what type of oil to use by brand and code, cheers
Re: puch x50 gear/clutch oil
Ben Van Zoest /
Look in the WIKI for Puch and print the service manual you will be needing it anyways...
