Kinetic Piston ring size
I need to replace the rings on my 2000 Kinetic TFR. I broke one accidentally putting the cylinder back in place and can't figure out what size to buy that would fit. Any one know of a source where I could find them? Thanks, bobby.
Re: Kinetic Piston ring size
check out zippymopedparts.com and/or cosmotor.com
Jonathan Davis /
did you ever figure this out??? looking for some for my 95 tfr...
38x2mm iirc, I think stock vespa rings should work, but you should measure the bore and ring thickness, then set the gap when installing to make sure.
Definitely check. Some kinetic cylinders are overbore compared to stock vespa.
