tomos lx problem HELP!!!!!!!!!!!!!!!!
I WAS RIDING MY LX down the road and it just shuts off...i had gas and oil. and now it wont pedal backworks witch means i cant start it. whats wrong???
thx
Re: tomos lx problem HELP!!!!!!!!!!!!!!!!
Your engine may have seized. Take the cover off the left side and see if you can turn the flywheel by hand. If the engine has seized, try to free it by spraying WD-40 into the spark plug hole and working the flywheel back and forth. But you may need to replace the piston and cylinder. Seizure is mainly caused by not having enough oil in the gas.
If you can turn the flywheel by hand but not by pedaling backwards, then something has gone wrong inside the transmission.
