Ok Rob, Take the Tape off the intake. This could cause serious problems. The solution Is simple. Assuming that everything is stock, then we can solve the problem. Bogging out as they say is the result of a bad fuel to air mixture. If you say that covering the intake makes it run better, then it is getting too much air for the CC's. Youre bike was made to work right. It has the right size jet for the carb, and it has the right size intake, and it has the right size exhaust. So how is it getting too much air? the air flow must be restricted. The size of the intake going into the engine must match what is coming out. You know the intake is not clogged. So if it is running Good when you are clogging the intake, you are essentially Matching the Output. So you can assume that you dont have enough flow out youre exhaust. This is a common Puch Problem, and the manual even details cleaning it once in a while. You can remove the screw from the end, and pull the baffle out. this is a little tube with two holes in it. Then you can pull the whole exhaust chamber off. Fill it with carb cleaner, shake it up, dump it out, and do it again. This should fix youre problem.
By covering half the intake, you essentially cut youre engine power in half. Knowing that, you now know how to make youre engine more powerfull. the only difference in the Puch engine sizes, between 1.5 and 2 hp was the airflow. You get a bigger intake, ie 15mm, you get more air going in. You also need a bigger jet, because you need more gas to go in wtih the air, and then you need a baffle with a 15mm hole for the exhaust. Get a bigger Carb.
Oh, and better yet, Take that hole baffle tube thing out of the exhaust. than you have no restrictions, and can get a vaccuum going. You have to rig up some sort of way to keep the muffler from falling off. You could also just drill a whole bunch of holes in the tube as well. let me know if that helps.
