Re: garelli carb
Rob K /
First of all, 25-30MPH on a stock Garelli moped is good. When you run that thing with the airbox removed, BE CAREFUL. You are making the thing run leaner. You may experience less acceleration from a stop when doing this.
Rejetting to a step smaller might be the good way to go, but you could mod the airbox (take the 2 plugs out first). Monitor the sparkplug after doing this to make sure it's not too lean (light tan or frosty white). You could seize it going on a downgrade...
