flywheel removal Video by Dan
Ok I made this so you can see how to do it you will notice im not pounding the shit out of it either
YouTube - flywheel removal with rubber malet Dan
Re: flywheel removal Video by Dan
Jason Luther /
that may work for one that has been removed within the past year
actually I took it off after 30 yrs with the same method Dan my motto is DONT BE SCARED
I dont care how long it has been on there I will take it off with my method it works and works well Dan
it does not work any more.
Bruce Wilkinson /
Dan, I don't know about you but, it sounds like THEMS FIGHTIN' WORDS from David.
ARRRRRG matey youll be wanting ta try this
YouTube - fly wheel removal
Video is working again
Re: Video is working again
Dan, i must admit i was a critic at first, but i tried it on the tomos i just got. the magneto was covered in rust, and it came right off! i took the sparkplug out, and pedaled it backwards with my hand while tapping on it with a hammer, and sure enough! popped off with no effort!
thank you for the tip,
-chad
The old guy still has a few tricks up his sleeve!!
you shouldn't be able to loosen the nut that easily. your flywheel will fly off!!!!! literally!!
Ithaca is too damn cold /
exactly. I tried this method and the nut is never that loose unless you've had it off before.
NailheadRocketman /
I just did half of the process, just used my trusty ratchet and a six point socket, hit it with a rubber mallet and the nut popped loose. I took it off with my finger. I still had to use my flywheel puller tool though, as the flywheel was really on there tight. I sprayed some wd40 on the crankshaft that was deep in the flywheel hole, screwed in my puller and placed my crescent wrench on that to hold it in place. I then gave a couple turns on the puller bolt and the flywheel came off with a little cracking sound. Everything went perfect.
Paul
