Motobecane
the crank feels like its slipping some times when I go to peddle start my bike. anyone ever have that problem? Is it normal? don't think its the belt. Are the crank shafts known to where out?
Re: Motobecane
on the big belt pulley the turn switch is not fully turned to motor
and the dog is slipping out of the gear. i had to mark mine so i knew when it was all the way in. look on the other side of pulley to see the gear and dog. remember to move the back wheel backwards so the dog is fully in the gear. you may need to lube the turn switch. don't force the switch just use you're hand to work it.
Re: Motobecane
roadent$ craig /
is your right chain loose?..i had this problem today actually...tighten it up
