this is a tomos a35. the pedal is jammed into the motor and the other side doesnt have a pedal or crank. i need some help how to unseize the motor. and how to get it running. thank you for the help
Is the engine really seized (can you turn the flywheel with your hand?) or are you just sayingthat you can't turn the pedals? Your post leaves a little to bedesired. It's a little vague. What do mean the pedal is jammed in to the motor?
no i cant turn it with my hand its seized
