Minarelli no speak
My Minarelli has no speak. So far I cleaned the points, regaped them, installes a new condenser . The Last owner told me it was left outside. Could the hi intence coils be bad?
Did I gap the points wrong(.018 like the book seid, but hard to see). If it is any help its a cev magneto and is the kill switch has one wire and can't see how it should work.
Re: Minarelli no speak
Go blue wire from magneto directly to coil. Make sure coil has a clean ground .This is the very basic ignition circuit. This should spark (plug pulled ,connected laying on cylinder). If it does great if not start checking for continuity(bad grounds etc) You may want to open the gap a bit more. A DVM on AC should pick up some voltage from the blue wire .
mine doesn't speak either, it puuuuuurrrrrrssss like a cat
meoeeoeoewww
I've heard of "Newspeak".
No speak, must be a newer form of that.
_Brain wave communications_!
---DeeZy
Cleats Onionpockets /
My puch doesn't talk much either...it just splutters a bit.
hey I work thrid shift and I'm beat in the morning. A few typos will get through
Ya know we're just jokin' with ya.
Did ya find any spark yet?
If you're needin' any specific motor parts, I have a parts motor.
Let me know if ya want anything off of it.
---_DeeZy_
FAIL PROOF WIRING
blue wire to coil. dont forget to ground the coil.
red wire to GROUND
black wire to GROUND
now you are ready!!
Unless of course, she's gotta bad coil or bad condensor, or her points aren't adjusted just right. Bad spark plug?
maybe you might tell me how this kill switch works. It just one red wire to a two pole switch. If it ground I don't see how. It a new condensor. The points are a bitch to set and I should get a new spark plug.My poor bike was abused , so please bear with me.
Kill switches are a little different on cifferent models.
I'd disconnect it for now until ya got spark. I don't even have one on my daily runner, I just shut'er off with the choke.
Maybe show me a picture of the killswitch. If ya can....
I might have another one if ya need it.
I like helping out Pennsylvanians, as I got a bunch of relatives over there. My Mom just brought back a bunch of Lebanon Bologne. MMMmmmm!
---_DeeZy_
Re: Minarelli no spark
Ok I have my point and magneto set right useing a mult meter. The piont break then they are supose to and I'm getting voltage. So, the problems is ether the coil or a short (I put the over or under on a short). The kill switch I figered out. It has one wire, but the second pole grounds to the handle bar through the houseing and hold down
