I broke my carb :(
Well, I got my carb rebuild kit from Ike today and when I was taking the float assembly out one of the little clips that holds the float thingy in broke off. I didn't even force it, it just came right off.
Is there anything I can do to repair it? Or would I be better off just getting a new carb. I mean it is only a 12mm carb and I plan on doing some light modifications to the magnum eventually. Is there a better alternative?
Re: I broke my carb :(
ooh that sucks! i always push mine out to the side with a pin instead of prying it out
Yeah, I probably should have done that but I've never taken one apart before. It came out the other side just fine.
is your magnum 1 speed or 2?
1 speed
I broke my carb :(
Kellen,
I have a carb body that you can have. Maybe we could work something out for this week or weekend. Don't buy one if you don't even know if it will run yet as a used one will run at least $25. You can have it for free. I can send it to you too as that might be faster.
Bryan
Sweet! Thanks bry. We can talk about it later in the chatroom.
