New Dellorto carbs verses old ones.Any difference?
I just bought an '80 Garelli which is missing the dellorto carb.
I have a dellorto carb from a '99 Tomos.
Will this carb work on the older peds?? It looks like it'll mount up fine, I was just wondering if it will run ok.
Thanks
Chas
Re: New Dellorto carbs verses old ones.Any differe
Should fit perfect, the only difference between the old and new dellorto sha carbs is that the old ones had a metal float bowl and the plastic parts were white. The new dellorto sha has a plastic Float bowl and black plastic top. It should work just as good as the stock one.
Grey
🇮🇹💦 Of the Loin /
dellorto carbs are champs!
Thanks for the info..
Now if I can only get this thing running. The previos owner tried all summer to fire it up and he couldn't do it. I have a feeling it's a issue with the points. I shall soon see.
Chas
