Re: Honda PA50II complete fuel loss frustration
Justin Campbell /
I agree with Silverfox. The carb is the most likely suspect. I had to clean mine a few times before it ran or idled correctly. Take your time and make it spotless. I always use non-hardening hi-temp gasket maker like permatex around the intake and reed valve, just to eliminate vacuum leaks. Should run like a champ after that though.
Good luck. Hobbits rule.
Justin
