Re: Honda PA50II complete fuel loss frustration
Leon Swarmer /
Mike, You said you filled the carb with new premix. Unless you've pulled off the bowl. or drained a little out from the bottom, you may not know that you filled the bowl. If the needle valve is stuck closed the fuel may not go into the carb.
