E50 help
OK, finally replaced the broken head stud. I am back to even on getting the stupid Puch running right. Here is what it does. It idles perfect, but no power at all, will not pull me for squat. It smokes a little too. I have replaced the plug, new stator, cond. points, new petcock. I really am just at a loss. Could it be the exhaust is packed?
Re: E50 help
See Ya Moped Army /
Yes. Remove the baffle from the exhaust and clean it thoroughly. The holes in the baffle are most likely plugged with carbon deposits. Also, make sure the header pipe is clear of grime and deposits. If there are restrictors in the header pipe, drill them out.
Re: E50 help
yep read the article on how to do that. it actually helps. use carbcleaner or superclean
Re: E50 help
Ok, where is that article, did a search could not find it.
Re: E50 help
The articles are under "resources" at the top of the page. I assume he's talking about Fred's Guide. Click on that and scroll down until you see "muffler clogged with carbon."
Re: E50 help
n actually im talking about De-restricting a Puch Maxi it under articles it helps your speed.
Re: E50 help
OK, I read both of those articles.First my header has way more holes in it than the De-restricting article. Second, how do I get the plastic baffles out of the pipe? That seem like they are really stuck in there. Thanks for the help so far.
Re: E50 help
ahah its actually is metal take a broom handle and slide the hole muffler onto it then just slam it down. the baffle is going to come up
Re: E50 help
See Ya Moped Army /
Plastic baffles in the pipe? I don't think so.
Re: E50 help
heheh, now that I think of it.
Re: E50 help
Yah, those baffles can be tough. After ruining several brooms, I bought a 5-foot length of fat re-rod and ground the end down to be rounded and blunt. Works great.
As for de-restricting, those two restrictors look the same as all the other holes at a glance, but they aren't just holes. They're tubes that go through the pipe and block the flow of exhaust. Not all pipes have them, but they're pretty easy to find if you look closely.
Re: E50 help
OK, did the fire pit last night. There were no tubes in the header, but a bunch of holes, and a bunch in the baffle. Still ran the same, no change. No power, idles good, smokes a little. What next?
Re: E50 help
if, it's not pulling you and it Has HIGH RPMs, it Could be the Clutch :(
Re: E50 help
It bogs down, not really High RPM's. as far as I can tell anyway.
Re: E50 help
What else could it be, I'm dying here. So far I have done this:
New petcock
new stator
points
condenser
cleaned the muffler
check the rings, piston, etc...
new carb in working order
so I am just at a loss. It idles great, but when I put gas to it it takes a while to speed up. When I ride it it dose not have enough power to pull me up any hill, or barely on flat. Kinda like it bogs down. Wish I had that damn book from fingers now, this is just killing me.
I am one step from taking the 357 out for some target practice.
Re: E50 help
See Ya Moped Army /
Do a compression check with a compression gauge, not your finger.
Re: E50 help
Yeah, sounds like you have a compression leak somewhere,How? did you check your rings? did you measure the ring Gap inside the cylinder?
Re: E50 help
Well, I got the ped on the word that the motor was rebuilt and all good. I guess it was not. I will try to get a compression gauge this weekend. This is a junker ped, I will not put much more time or $ into the damn thing. I will part out or just beat the shit out of it.
