Re: Why is my Motobecane 50V clutch area so loud?
keller_stephen /
Atten ALL! You may need to grease your variator! there is an inverse zirk on the left and side of clutch...the part that spins when engine is running! There used to be a factory grease gun for this but they are rare...almost impossible to find any more. I used a needle fitting from a reg grease gun with the needle removed...it takes 2-3 pumps every 3,000 or 4,000 miles.....this is very important to the health and well being of variator! I have seen many mobys relegated to scrap with out this maint! clean the goop out off the fitting and look in there there is a brass fitting..you should get the point..if this goes on long enough the engine will not swing back from its farthest point of retraction as in after climbing a hil...you will be stuck in high...it may bang back suddenly or you may need it too cool down first! LUBE your varriators! We all know what comes of a lack of lubrication! Peace and Good luck!
  Why is my Motobecane 50V clutch area so loud?Topic by: brystheguy brystheguy 09/28/06 12:40AM
  Re: Why is my Motobecane 50V clutch area so loud?Re: motochick motochick 09/28/06 01:52AM
  Re: Why is my Motobecane 50V clutch area so loud?Re: Ernie Wan Ernie Wan 10/28/14 04:43PM
  Re: Why is my Motobecane 50V clutch area so loud?Re: ಠ_ಠ Jon Folks ಠ_ಠ ಠ_ಠ Jon Folks ಠ_ಠ 09/28/06 02:39AM
  Re: Why is my Motobecane 50V clutch area so loud?Re: Willie Willie 09/28/06 02:47AM
  Re: Why is my Motobecane 50V clutch area so loud?Re: Gabe Gabe 09/28/06 09:58AM
  Re: Why is my Motobecane 50V clutch area so loud?Re: keller_stephen keller_stephen 09/29/06 03:37AM
  Re: Why is my Motobecane 50V clutch area so loud?Re: Hayden Stevens Hayden Stevens 09/29/06 05:18AM
  Why is my Motobecane 50V clutch area so loud?Re: brystheguy brystheguy 09/28/06 05:08PM
  Re: Why is my Motobecane 50V clutch area so loud?Re: Hayden Stevens Hayden Stevens 09/28/06 09:11PM
  Re: Why is my Motobecane 50V clutch area so loud?Re: rthor rthor 09/29/06 12:04AM
  Re: Why is my Motobecane 50V clutch area so loud?Re: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 09/29/06 01:35AM
  Re: Why is my Motobecane 50V clutch area so loud?Re: Michael Dane Michael Dane 09/29/06 06:54PM
  Re: Why is my Motobecane 50V clutch area so loud?Re: matt madden matt madden 10/29/14 10:10AM
  Re: Why is my Motobecane 50V clutch area so loud?Re: Ernie Wan Ernie Wan 10/29/14 12:01PM
  Re: Why is my Motobecane 50V clutch area so loud?Re: scott middleton scott middleton 10/29/14 12:33PM
  Re: Why is my Motobecane 50V clutch area so loud?Re: Rebel Moby Rebel Moby 10/29/14 01:16PM
  Re: Why is my Motobecane 50V clutch area so loud?Re: Ernie Wan Ernie Wan 10/29/14 02:22PM
  Re: Why is my Motobecane 50V clutch area so loud?Re: Rebel Moby Rebel Moby 10/29/14 03:22PM
  Re: Why is my Motobecane 50V clutch area so loud?Re: javier f javier f 10/30/14 04:26AM
  Re: Why is my Motobecane 50V clutch area so loud?Re: scott middleton scott middleton 10/30/14 03:13PM
  Re: Why is my Motobecane 50V clutch area so loud?Re: matt madden matt madden 10/30/14 05:24PM
  Re: Why is my Motobecane 50V clutch area so loud?Re: matt madden matt madden 10/30/14 09:47AM
  Re: Why is my Motobecane 50V clutch area so loud?Re: Ernie Wan Ernie Wan 10/30/14 05:01PM
  Re: Why is my Motobecane 50V clutch area so loud?Re: matt madden matt madden 10/30/14 05:11PM
  Re: Why is my Motobecane 50V clutch area so loud?Re: scott middleton scott middleton 10/31/14 11:06AM
  Re: Why is my Motobecane 50V clutch area so loud?Re: javier f javier f 10/31/14 12:36PM
  Re: Why is my Motobecane 50V clutch area so loud?Re: Rebel Moby Rebel Moby 10/31/14 12:58PM
