TTLX broken head bolt
I have an A35 motor with a stud broken off in the crank case. Any ideas on how to remove it would be appreciated. I should probably mention that it is broken off below the surface of the crank case.
Thanks,
-Eric
Re: TTLX broken head bolt
John Joedicke /
Your only option is to drill it out. Use a ez-out or hope it turns out with the drill. Re-tap to clean up the threads.
