Re: Still having problems with a Puch Newport
blackfingers /
i have been screwing around with a newport for the past few weeks, with EXACTLY the same problems - i did everything you have done as well, and still nothing. check the cylinder for the type - mine has a 22 on it (the number is on the mating surfaces of the top and botton ends...) this 22 indicates a high compression cylinder - so i checked the compression, and it was around 65psi - way to low for even a standard cylinder... so looking through a couple manuals, i came across a note that the 22 cylinder should have a .60mm head gasket, which is not the standard for puch engines - with the cylinders, damage to the head gaskets can allow horsepower to bleed out, and having to little clearance can change the port timing - while this may or may not make a huge difference, i would say that you should test the compression. if its lower than 120psi, decarbonize the engine, replace the piston rings, head gasket, and hone the cylinder -
  Still having problems with a Puch NewportTopic by: Motobecane Master Motobecane Master 09/14/06 08:10PM
  Re: Still having problems with a Puch NewportRe: Tom B. Tom B. 09/14/06 09:58PM
  Re: Still having problems with a Puch NewportRe: Jason Luther Jason Luther 09/14/06 10:39PM
  Re: Still having problems with a Puch NewportRe: Jason Luther Jason Luther 09/14/06 10:41PM
  Re: Still having problems with a Puch NewportRe: Motobecane Master Motobecane Master 09/14/06 11:52PM
  Re: Still having problems with a Puch NewportRe: Jason Luther Jason Luther 09/15/06 07:37AM
  Re: Still having problems with a Puch NewportRe: Daniel Van Donsel Daniel Van Donsel 09/26/06 05:07AM
  Re: Still having problems with a Puch NewportRe: Motobecane Master Motobecane Master 09/16/06 07:34PM
  Re: Still having problems with a Puch NewportRe: Leon Swarmer Leon Swarmer 09/16/06 09:05PM
  Re: Still having problems with a Puch NewportRe: Gene Gindling Gene Gindling 09/16/06 09:41PM
  Re: Still having problems with a Puch NewportRe: Motobecane Master Motobecane Master 09/17/06 12:26AM
  Re: Still having problems with a Puch NewportRe: tim tim 09/17/06 10:15AM
  Re: Still having problems with a Puch NewportRe: Jeff Jeff 09/18/06 05:55PM
  Re: Still having problems with a Puch NewportRe: Motobecane Master Motobecane Master 09/19/06 12:08AM
  Re: Still having problems with a Puch NewportRe: Motobecane Master Motobecane Master 09/19/06 12:50AM
  Re: Still having problems with a Puch NewportRe: Jeff Jeff 09/19/06 10:53AM
  Re: Still having problems with a Puch NewportRe: Ben Van Zoest Ben Van Zoest 09/18/06 10:25PM
  Re: Still having problems with a Puch NewportRe: KenFong KenFong 09/22/06 12:36AM
  Re: Still having problems with a Puch NewportRe: Ben Van Zoest Ben Van Zoest 10/12/06 10:38AM
  Re: Still having problems with a Puch NewportRe: Rick Rick 09/22/06 12:38AM
  Re: Still having problems with a Puch NewportRe: Motobecane Master Motobecane Master 09/22/06 12:45AM
  Re: Still having problems with a Puch NewportRe: Willie Willie 09/22/06 06:40AM
  Re: Still having problems with a Puch NewportRe: blackfingers blackfingers 09/22/06 08:44PM
  Re: Still having problems with a Puch NewportRe: Dan Dan 09/22/06 08:52PM
  Re: Still having problems with a Puch NewportRe: Dan Dan 09/23/06 09:59AM
  Re: Still having problems with a Puch NewportRe: Motobecane Master Motobecane Master 09/24/06 04:59PM
  Re: Still having problems with a Puch NewportRe: Dan Dan 09/24/06 09:22PM
  Re: Still having problems with a Puch NewportRe: Colin Colin 09/26/06 11:36AM
  Re: Still having problems with a Puch NewportRe: bryanrobo bryanrobo 09/27/06 09:28PM
  Re: Still having problems with a Puch NewportRe: Motobecane Master Motobecane Master 09/28/06 10:59PM
  Still having problems with a Puch NewportRe: Motobecane Master Motobecane Master 10/02/06 01:09AM
  Still having problems with a Puch NewportRe: Motobecane Master Motobecane Master 10/09/06 02:30PM
  Re: Still having problems with a Puch NewportRe: Dan Dan 10/09/06 11:30PM
  Re: Still having problems with a Puch NewportRe: Motobecane Master Motobecane Master 10/11/06 10:25AM
  Re: Still having problems with a Puch NewportRe: Gabe Gabe 10/11/06 10:46AM
  Re: Still having problems with a Puch NewportRe: bryanrobo bryanrobo 10/11/06 09:01PM
  Re: Still having problems with a Puch NewportRe: Ben Van Zoest Ben Van Zoest 10/12/06 10:42AM
