Re: Still having problems with a Puch Newport
Willie /
It could be an air leak around the base of the intake manifold. That happened to me a couple weeks ago. Make sure the manifold gasket is good, and the two nuts bolting it on are tight. Then, and this may sound obvious, make sure the screw clamping the carb onto the manifold is tight. Then, if neither of those suggestions help, buy one size smaller jet (52), and one size larger jet (56) and try them both. In my experience, running with or without the air filter has absolutely no effect on performance, so don't worry if you don't have a snorkel, but that's just my experience. The amount of air going through is _primarily_ determined by the size of the venturi. If none of those things fix it, check your timing (should be 2mm btdc) and your compression (should be 120psi-140psi).
Hope this helps,
Willie.
  Still having problems with a Puch NewportTopic by: Motobecane Master Motobecane Master 09/14/06 08:10PM
  Re: Still having problems with a Puch NewportRe: Tom B. Tom B. 09/14/06 09:58PM
  Re: Still having problems with a Puch NewportRe: Jason Luther Jason Luther 09/14/06 10:39PM
  Re: Still having problems with a Puch NewportRe: Jason Luther Jason Luther 09/14/06 10:41PM
  Re: Still having problems with a Puch NewportRe: Motobecane Master Motobecane Master 09/14/06 11:52PM
  Re: Still having problems with a Puch NewportRe: Jason Luther Jason Luther 09/15/06 07:37AM
  Re: Still having problems with a Puch NewportRe: Daniel Van Donsel Daniel Van Donsel 09/26/06 05:07AM
  Re: Still having problems with a Puch NewportRe: Motobecane Master Motobecane Master 09/16/06 07:34PM
  Re: Still having problems with a Puch NewportRe: Leon Swarmer Leon Swarmer 09/16/06 09:05PM
  Re: Still having problems with a Puch NewportRe: Gene Gindling Gene Gindling 09/16/06 09:41PM
  Re: Still having problems with a Puch NewportRe: Motobecane Master Motobecane Master 09/17/06 12:26AM
  Re: Still having problems with a Puch NewportRe: tim tim 09/17/06 10:15AM
  Re: Still having problems with a Puch NewportRe: Jeff Jeff 09/18/06 05:55PM
  Re: Still having problems with a Puch NewportRe: Motobecane Master Motobecane Master 09/19/06 12:08AM
  Re: Still having problems with a Puch NewportRe: Motobecane Master Motobecane Master 09/19/06 12:50AM
  Re: Still having problems with a Puch NewportRe: Jeff Jeff 09/19/06 10:53AM
  Re: Still having problems with a Puch NewportRe: Ben Van Zoest Ben Van Zoest 09/18/06 10:25PM
  Re: Still having problems with a Puch NewportRe: KenFong KenFong 09/22/06 12:36AM
  Re: Still having problems with a Puch NewportRe: Ben Van Zoest Ben Van Zoest 10/12/06 10:38AM
  Re: Still having problems with a Puch NewportRe: Rick Rick 09/22/06 12:38AM
  Re: Still having problems with a Puch NewportRe: Motobecane Master Motobecane Master 09/22/06 12:45AM
  Re: Still having problems with a Puch NewportRe: Willie Willie 09/22/06 06:40AM
  Re: Still having problems with a Puch NewportRe: blackfingers blackfingers 09/22/06 08:44PM
  Re: Still having problems with a Puch NewportRe: Dan Dan 09/22/06 08:52PM
  Re: Still having problems with a Puch NewportRe: Dan Dan 09/23/06 09:59AM
  Re: Still having problems with a Puch NewportRe: Motobecane Master Motobecane Master 09/24/06 04:59PM
  Re: Still having problems with a Puch NewportRe: Dan Dan 09/24/06 09:22PM
  Re: Still having problems with a Puch NewportRe: Colin Colin 09/26/06 11:36AM
  Re: Still having problems with a Puch NewportRe: bryanrobo bryanrobo 09/27/06 09:28PM
  Re: Still having problems with a Puch NewportRe: Motobecane Master Motobecane Master 09/28/06 10:59PM
  Still having problems with a Puch NewportRe: Motobecane Master Motobecane Master 10/02/06 01:09AM
  Still having problems with a Puch NewportRe: Motobecane Master Motobecane Master 10/09/06 02:30PM
  Re: Still having problems with a Puch NewportRe: Dan Dan 10/09/06 11:30PM
  Re: Still having problems with a Puch NewportRe: Motobecane Master Motobecane Master 10/11/06 10:25AM
  Re: Still having problems with a Puch NewportRe: Gabe Gabe 10/11/06 10:46AM
  Re: Still having problems with a Puch NewportRe: bryanrobo bryanrobo 10/11/06 09:01PM
  Re: Still having problems with a Puch NewportRe: Ben Van Zoest Ben Van Zoest 10/12/06 10:42AM
