Re: Still having problems with a Puch Newport
Motobecane Master /
So I cleaned out the petcock, fuel's flowing freely from there. What I now believe the problem to be is that the tube running from the petcock to the carb is crimped. It looks like it wasn't long enough when it was installed (I don't think it's the original because it has a filter on it) and it's crimped where it had to bend up to the petcock. Fuel goes through it but it may be causing enough blockage to bog it down at faster speeds. Since it's been that way for probably at least a decade I can't get the crimp out completely.
I'm going to look for a new one at a few motorcycle shops around here Monday and see if that solves the problem. If not, it's back to the drawing board.
This is just something else that may help identify a cause for the bogging. I've been able to get the bike to full throttle while on its stand if I ease into it really slow. If I give it full throttle right away it bogs. With me on it (I weigh all of 145 pounds) I can't get it to full throttle at all. Hope that helps.
Again, thanks.
  Still having problems with a Puch NewportTopic by: Motobecane Master Motobecane Master 09/14/06 08:10PM
  Re: Still having problems with a Puch NewportRe: Tom B. Tom B. 09/14/06 09:58PM
  Re: Still having problems with a Puch NewportRe: Jason Luther Jason Luther 09/14/06 10:39PM
  Re: Still having problems with a Puch NewportRe: Jason Luther Jason Luther 09/14/06 10:41PM
  Re: Still having problems with a Puch NewportRe: Motobecane Master Motobecane Master 09/14/06 11:52PM
  Re: Still having problems with a Puch NewportRe: Jason Luther Jason Luther 09/15/06 07:37AM
  Re: Still having problems with a Puch NewportRe: Daniel Van Donsel Daniel Van Donsel 09/26/06 05:07AM
  Re: Still having problems with a Puch NewportRe: Motobecane Master Motobecane Master 09/16/06 07:34PM
  Re: Still having problems with a Puch NewportRe: Leon Swarmer Leon Swarmer 09/16/06 09:05PM
  Re: Still having problems with a Puch NewportRe: Gene Gindling Gene Gindling 09/16/06 09:41PM
  Re: Still having problems with a Puch NewportRe: Motobecane Master Motobecane Master 09/17/06 12:26AM
  Re: Still having problems with a Puch NewportRe: tim tim 09/17/06 10:15AM
  Re: Still having problems with a Puch NewportRe: Jeff Jeff 09/18/06 05:55PM
  Re: Still having problems with a Puch NewportRe: Motobecane Master Motobecane Master 09/19/06 12:08AM
  Re: Still having problems with a Puch NewportRe: Motobecane Master Motobecane Master 09/19/06 12:50AM
  Re: Still having problems with a Puch NewportRe: Jeff Jeff 09/19/06 10:53AM
  Re: Still having problems with a Puch NewportRe: Ben Van Zoest Ben Van Zoest 09/18/06 10:25PM
  Re: Still having problems with a Puch NewportRe: KenFong KenFong 09/22/06 12:36AM
  Re: Still having problems with a Puch NewportRe: Ben Van Zoest Ben Van Zoest 10/12/06 10:38AM
  Re: Still having problems with a Puch NewportRe: Rick Rick 09/22/06 12:38AM
  Re: Still having problems with a Puch NewportRe: Motobecane Master Motobecane Master 09/22/06 12:45AM
  Re: Still having problems with a Puch NewportRe: Willie Willie 09/22/06 06:40AM
  Re: Still having problems with a Puch NewportRe: blackfingers blackfingers 09/22/06 08:44PM
  Re: Still having problems with a Puch NewportRe: Dan Dan 09/22/06 08:52PM
  Re: Still having problems with a Puch NewportRe: Dan Dan 09/23/06 09:59AM
  Re: Still having problems with a Puch NewportRe: Motobecane Master Motobecane Master 09/24/06 04:59PM
  Re: Still having problems with a Puch NewportRe: Dan Dan 09/24/06 09:22PM
  Re: Still having problems with a Puch NewportRe: Colin Colin 09/26/06 11:36AM
  Re: Still having problems with a Puch NewportRe: bryanrobo bryanrobo 09/27/06 09:28PM
  Re: Still having problems with a Puch NewportRe: Motobecane Master Motobecane Master 09/28/06 10:59PM
  Still having problems with a Puch NewportRe: Motobecane Master Motobecane Master 10/02/06 01:09AM
  Still having problems with a Puch NewportRe: Motobecane Master Motobecane Master 10/09/06 02:30PM
  Re: Still having problems with a Puch NewportRe: Dan Dan 10/09/06 11:30PM
  Re: Still having problems with a Puch NewportRe: Motobecane Master Motobecane Master 10/11/06 10:25AM
  Re: Still having problems with a Puch NewportRe: Gabe Gabe 10/11/06 10:46AM
  Re: Still having problems with a Puch NewportRe: bryanrobo bryanrobo 10/11/06 09:01PM
  Re: Still having problems with a Puch NewportRe: Ben Van Zoest Ben Van Zoest 10/12/06 10:42AM
