Still having problems with a Puch Newport
Motobecane Master /
I posted a few days ago with what I thought was problems with my Puch Newport not shifting into second gear. Well, here's the thing; I now know that it's only a 1 speed bike.
That clears up the possibility of the clutches sticking (correct me if I'm wrong) but the problem still stands.
What it does is it runs fine, idles, starts great, but as soon as it gets to 15-20 mph it starts to bog down. If I keep giving it gas it stops completely. I'm losing my mind trying to fix this thing.
Here is a list of everything I've checked:
transmission fluid changed (added 5.5 oz. of type F)
carb cleaned and assembled correctly, choke slide is staying up
gas mixture is correct (2.5 oz of oild per gallon)
cleaned the air filter and fitted it tight to carb
cleaned the muffler and pipe coming from the engine, there are no clogs
Basically I've done everything I can think of to try to fix the problem.
I know of three problems with the bike, all of which I'm fairly certain shouldn't be doing anything, let alone causing such a loss of power. The carb top gasket is not perfect, it has a rip but it still covers everything. Also, the plastic tube that used to be on the airbox (as far as I can tell from pictures) is gone. That, I've been told, does next to nothing for the moped for good or worse. Last, the cork that used to line the gas cap is gone.
Please please please, I'm willing to stick this thread out and do whatever it takes to get this thing running correctly. It's a beautiful bike and has no other problems (ok, the headlight goes out when I hit the horn button but that's a wiring problem I'm going to worry about once I get the damn thing running right).
I'd appreciate any help, thanks.
  Still having problems with a Puch NewportTopic by: Motobecane Master Motobecane Master 09/14/06 08:10PM
  Re: Still having problems with a Puch NewportRe: Tom B. Tom B. 09/14/06 09:58PM
  Re: Still having problems with a Puch NewportRe: Jason Luther Jason Luther 09/14/06 10:39PM
  Re: Still having problems with a Puch NewportRe: Jason Luther Jason Luther 09/14/06 10:41PM
  Re: Still having problems with a Puch NewportRe: Motobecane Master Motobecane Master 09/14/06 11:52PM
  Re: Still having problems with a Puch NewportRe: Jason Luther Jason Luther 09/15/06 07:37AM
  Re: Still having problems with a Puch NewportRe: Daniel Van Donsel Daniel Van Donsel 09/26/06 05:07AM
  Re: Still having problems with a Puch NewportRe: Motobecane Master Motobecane Master 09/16/06 07:34PM
  Re: Still having problems with a Puch NewportRe: Leon Swarmer Leon Swarmer 09/16/06 09:05PM
  Re: Still having problems with a Puch NewportRe: Gene Gindling Gene Gindling 09/16/06 09:41PM
  Re: Still having problems with a Puch NewportRe: Motobecane Master Motobecane Master 09/17/06 12:26AM
  Re: Still having problems with a Puch NewportRe: tim tim 09/17/06 10:15AM
  Re: Still having problems with a Puch NewportRe: Jeff Jeff 09/18/06 05:55PM
  Re: Still having problems with a Puch NewportRe: Motobecane Master Motobecane Master 09/19/06 12:08AM
  Re: Still having problems with a Puch NewportRe: Motobecane Master Motobecane Master 09/19/06 12:50AM
  Re: Still having problems with a Puch NewportRe: Jeff Jeff 09/19/06 10:53AM
  Re: Still having problems with a Puch NewportRe: Ben Van Zoest Ben Van Zoest 09/18/06 10:25PM
  Re: Still having problems with a Puch NewportRe: KenFong KenFong 09/22/06 12:36AM
  Re: Still having problems with a Puch NewportRe: Ben Van Zoest Ben Van Zoest 10/12/06 10:38AM
  Re: Still having problems with a Puch NewportRe: Rick Rick 09/22/06 12:38AM
  Re: Still having problems with a Puch NewportRe: Motobecane Master Motobecane Master 09/22/06 12:45AM
  Re: Still having problems with a Puch NewportRe: Willie Willie 09/22/06 06:40AM
  Re: Still having problems with a Puch NewportRe: blackfingers blackfingers 09/22/06 08:44PM
  Re: Still having problems with a Puch NewportRe: Dan Dan 09/22/06 08:52PM
  Re: Still having problems with a Puch NewportRe: Dan Dan 09/23/06 09:59AM
  Re: Still having problems with a Puch NewportRe: Motobecane Master Motobecane Master 09/24/06 04:59PM
  Re: Still having problems with a Puch NewportRe: Dan Dan 09/24/06 09:22PM
  Re: Still having problems with a Puch NewportRe: Colin Colin 09/26/06 11:36AM
  Re: Still having problems with a Puch NewportRe: bryanrobo bryanrobo 09/27/06 09:28PM
  Re: Still having problems with a Puch NewportRe: Motobecane Master Motobecane Master 09/28/06 10:59PM
  Still having problems with a Puch NewportRe: Motobecane Master Motobecane Master 10/02/06 01:09AM
  Still having problems with a Puch NewportRe: Motobecane Master Motobecane Master 10/09/06 02:30PM
  Re: Still having problems with a Puch NewportRe: Dan Dan 10/09/06 11:30PM
  Re: Still having problems with a Puch NewportRe: Motobecane Master Motobecane Master 10/11/06 10:25AM
  Re: Still having problems with a Puch NewportRe: Gabe Gabe 10/11/06 10:46AM
  Re: Still having problems with a Puch NewportRe: bryanrobo bryanrobo 10/11/06 09:01PM
  Re: Still having problems with a Puch NewportRe: Ben Van Zoest Ben Van Zoest 10/12/06 10:42AM
