Do the A35's have head gaskets?
Nope, you might be able to use a puch one if you wanted though.
Grey
Grey - could you tell us - would there be any advantage to a head gasket?
the reason i ask is when i first bought my tomos i put a cork head gasket in and had it for about 100 miles then someone clarified for me that it wasnt missing a gasket it never had one - so i removed it.
just curious if there would be any advantage - less need to deck every once in a while etc
I don't really think there is an advantage unless you're really having sealing problems. A flat, smooth and clean mounting surface should seal just fine.
Grey
If I'm not mistaken, the early A35's had head gaskets.
I've heard that also, but I've never seen one in person.
Yes its true early a-35s did. Around 95-92
thanks for clarifying that :-)
I hae a 93 TTLX and I don't have a head gasket, but it's possible it was taken apart before so I wanted to be sure....If you have 95-92 is it required? Doesn't run right and I've been through EVERYTHING....
