Weird Air Problem
I installed an inline fuel filter and when i turned the petcock to the on position, no fuel came out unless I tapped the "tickler" on the carb. I took the cap off the gas tank...nothing different, then I detached the fuel line from the petcock and turned it on and gas flowed steadily out. What could cause this?
Re: Weird Air Problem
You may want to look through your fuel hose. LOL
If your carb bowl is full, the float needle will be sealing the fuel inlet on the carb. A sort of air lock forms, preventing the fuel from flowing. The "tickler" opens the needle valve, allowing fuel to flow.
Ben Van Zoest /
Top off the tank the extra weight can drive out the air bubble
I had the same thing after installing an in-line disc filter and new see through urethane hose which tipped me of on the air bubble than viseable. After you run for a mile or so the line should be clear and flowing normally..
