not starting, but has spark?
brystheguy /
Another thing to check are the wires that run down by the neck. I just had a Free Spirit that had intermittent ignition problems and discovered that the wires were chewed up after being pinched in between the fork and the fork stop. There was enough wire for it to run if the bars were straight but not if you turned them. Worth a check anyway.
