Re: Troublesome seat spring install-vespa ciao
It helps to have another person work with you to compress the spring. Stand over rack facing toward the seat and compress it while the other person puts that nut on the bottom of the bolt. Also, make sure that the big rubber washer is in the correct spot, otherwise you will not be able to compress that spring nearly enough. Hope that helps.
Cheers,
Brennen
