Honda NC50 1981 Automatic choke advice needed
I lucked out and found a 1981 NC50 Express.
The restoration process is going great except for the automatic choke that is connected to the head. Does anyone
have any words of wisdom before I clean it ? I have not
taken one apart and could use some moped army mechanical advice. I have used the search function and
did not find enough detailed information on the subject.
Brian
Re: Honda NC50 1981 Automatic choke advice needed
Do a search for the site `Expressly Mopeds' run by the MopedWhiz. There is a vast amount of info. on the Honda Express. When you do a saearch on that site,hit `cached' to see your result.
The above is true unless they have changed the site. don-ohio
Leon Swarmer /
also, go the the repair forum and serach for what JAX184 has said.
Leon Swarmer /
my bad, you are on the right forum..sorry,
JAX184 has it right !
If you take apart your carburator,
it is important not to open the automatic choke box !
The lines from the carb to the automatic choke and such can crack and leak.
If this happens you will have a hard time starting and idling.
They are easy to replace.
Taking it apart would be a big mistake thanks JAX184 !
I'm ok with this the next question is how do I test it ?
Brian
