battery
i just ordered a battery for my fa 50 susuki, my question is, how do i charge such a small battery? i have a normal charger that can charge 6 volt batteries, it just seems like that is too much for that little battery. thanks dave
Re: battery
Steamboat Aka J. R. Stevens /
I don't know what you mean by "normal charger" but I have used an automobile charger on motorcycle batteries. Jim.
Re: battery
this is a charger that i charge my 12 volt auto batteries and 6 volt farm tractor batteries with. more than likely i can use this charger, however i'd sure like to make sure before i try so i don't ruin this new little battery. thanks for any help
dave
Re: battery
Don't let the battery boil and no open flames. Jim
Re: battery
thanks for your help, dave
Re: battery
Any battery charger that will switch to six volts is fine. One that is labeled "automatic" will automatically shut down when the battery is charged. Other ones (not automatic) must be timed since they will continue to send power to the battery. There are formulae for how much charge it has now (percent of charge) and what size the battery is. There may not be a formula for such a small battery.
If your charger is not automatic, just charge it for a short time (like 30 minutes). If your charger is not automatic and high amperage (above ten) make it less time. Then check to see if it's boiling inside. If so, take it off the charge and try it. When it's still charging, there should be small bubbles, but not big ones.
If you have a voltmeter, watch the voltage during charging. It should increase as the battery charges. When it stops increasing, the battery is fully opposing the voltage of the charger and should be fully charged.
Dave Gibbons
Re: battery
The direction that came with my new battery said charge at no more than 2 Amps untill the specific graverty of the electorlyte rises to higher than 1.270 A faster rate will shorting the life of your new battery
Re: battery
Leon Swarmer /
yep yep yep, I use a littel 7.5 v transfomer to charge mine...slower is better for these little guys
