Truing the rim first
Hello All,
I am reaching the critical mass of my moped (magnum xk '78 i think) knowledge, that is to say without advice i am likely to start hurting things more than repairing them...
Truing the front wheel...had some serious wows in it, the problem i am facing now is that some spokes are so tight that they will not tighten more while others are pretty lose and the wheel is not true yet. This is the case on both sides, that is the rim is not pulled all the way to the left and needs to go to the right, some sections are one way and others the other way...
Thanks
-nathan
Re: Truing the rim first
bump
Ok, you really need to re-tension your wheel.
WARNING: Plan to spend from 4 to 6 hours on the following process.
Take the wheel off your 'ped, take the tire off, and put the wheel
on a truing stand (could just be a piece of pipe through your wheel,
with the pipe in a bench vise).
Loosen all the spokes until they go thump instead of
_ting_.
Now, get something to measure your deflection. You really
want to get yourself a dial caliper set ("$25 at Harbor Freight tools":http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=93051 )
If you're a cheap-ass, a magic marker clamped so that the tip just barely
touches the highest spot (and you lower it as you true, and wipe off the
marker as you go) will do in a pinch.
And speaking of magic markers, make your like easier by putting a piece
of making tape all around your rim so that you can number your spokes.
It'll save a lot of time if you need to undo a step, or if you have a
troublesome area.
Anyhow, here are my stages to truing a wheel:
(I'm assuming you are truing it horizontal)
Gross up/down
In this phase, you will be tightening all of your spokes so that the
will is _basically_ flat, and your rim is centered on your hub.
DO NOT OVER TIGHTEN HERE! You will need to spare tension later.
You just need to bring the rim in line with the hub's center.
Gross in/out
Using just a 1/4 turn at a time, adjust the spokes so that when
you spin the wheel, it's _mostly_ round. A 1/8" deflection is
fine.
Fine up/down
Now, we get rid of the 'bumps' in the wheel. In this phase, your
dial caliper (or marker) should be hitting high points either between
or right on a spoke. If right on, tighten for spokes that go down,
and loosen for spokes that go up. If between, adjust both spokes.
Remember - GO SLOW! Only tighten by a 1/4 turn, then move on to
another part of the wheel. If you work only on one side at a time,
that side will be over tightened, and, like a spring, will rapidly deflect
when you adjust the other side.
You're looking for a final deflection of about 1/16", and your spokes
should go _tang_. Not _ting_ yet, but we're getting there!
Fine in/out
Same as fine up/down, but when you adjust for in/out deflection,
you must tighten or loosen two or more spokes at a time -
one going 'up', and one going 'down'. They must be adjusted
at the same time, and, please check your up/down deflection after
every in/out adjustment!
I cannot stress this more - if you over tighten during the in/out phase,
you can rapidly warp your wheel out of true. If you check up/down
every time, it's easy to undo what you last did.
Torqing
Now come the what you've been waiting for - _ting_ _ting_ _ting_
This is the trickiest part - you need to _gradually_ adjust all the
spokes to be in tension without messing up all of your hard work.
What I usually do is rig up the dial caliper to right where I'll be
doing the adjustments (set for measuring up/down deflection),
and tighten only the loosest spokes until the tiniest deflection is
measured, then back off a little. I go round and round, slowly
torquing it all in, a little at a time, until all the spokes make a nice
_ting_ sound. For my wheels, a higher pitched _tink_ sound is
too much, and I back off.
You're Done!
Re-tire and mount your wheel, and have fun!
Hmm. I should probably put this on the wiki..
http://www.mopedarmy.com/wiki/Wheel_Truing
Leon Swarmer /
excellent write up Jason.
Thanks. It was all fresh in my mind, as I had to true my rear wheel
last week.
I was in a hurry, and got it all wrong. I had deflections of over 1/4"
of an inch, and all my spokes went thump.
So, I talked to a guy at my office who makes his own bicycle wheel ... _for fun_ ...
and I got a lot of great hints from him.
So I went back, took the tire off (puncturing my tube in the process
- DOH! - ) and followed his advice.
After 4 hours of following the above procedure, I had it perfectly
tensioned, with a final deflection of +/- 0.02 inches (that's half a millimeter,
for the rest of the world) on both in/out and up/down.
I was beaming for _days_, I was so proud of myself
Thank you so much for the in-depth adivce, although i do not look forward to undoing all that i did, a striaght wheel is better than an almost striaght wheel any day!
thank you again.
