Backfireing on decelleration is the problem of the day. Here's whats goin down...
After cleaning the carb good, readjusting the idle screw and checking for (what i see as) good gas flow, i took the ped out for a quick test run. Everything seems to be okay, speeds up to about 20 (which is as good as i can get it running so far) on decleration the ped is backfiring. Before i cleaned the carb it sounded and felt like it was backfireing from the airbox (felt rushes of air on my right ancle) Any thoughts? I thought backfire usually came from the exaust no?
