does this sound like soft sieze
mws /
could it be soft seize???? symptoms??
I got the tomos running, has no airfilter, i know it might be too lean, has a BiTurbo and a 53 jet, I was testing things out, function of transmission, limiting air into carb to see if it will shift better.
It was running pretty good, shifting was questionable, sometimes getting into 2nd, and sometimes lacking RPM power to get to 2nd.
then going around block, heard a clicking sound, then it just staled and slammed to a stop, not from brakes, but from friction like, i thought I just blew the motor, but it started right up???? Could it be to hot.......not getting right air-gas-oil mixture.......i think i'm going to take off oil injector, and try playing with carb filters, i checked the trans, my cork 1st gear clutch is kindoff warn, can't see 2nd gear clutch yet......i'll try a mirror....
  does this sound like soft siezeTopic by: mws mws 09/11/06 07:01PM
  Re: does this sound like soft siezeRe: Jason Luther Jason Luther 09/11/06 07:26PM
  Re: does this sound like soft siezeRe: Saabsonettguy . Saabsonettguy . 09/11/06 08:10PM
  Re: does this sound like soft siezeRe: mws mws 09/11/06 08:22PM
  Re: does this sound like soft siezeRe: mws mws 09/11/06 08:24PM
  Re: does this sound like soft siezeRe: See Ya Moped Army See Ya Moped Army 09/11/06 08:29PM
  Re: does this sound like soft siezeRe: mws mws 09/11/06 08:37PM
  Re: does this sound like soft siezeRe: Saabsonettguy . Saabsonettguy . 09/11/06 08:58PM
  Re: does this sound like soft siezeRe: Jason Luther Jason Luther 09/11/06 10:16PM
  Re: does this sound like soft siezeRe: Ben Van Zoest Ben Van Zoest 09/12/06 01:57PM
  Re: does this sound like soft siezeRe: mws mws 09/11/06 10:26PM
  Re: does this sound like soft siezeRe: Spocko Spocko 09/11/06 11:08PM
  Re: does this sound like soft siezeRe: mws mws 09/11/06 11:17PM
  Re: does this sound like soft siezeRe: Cleats Onionpockets Cleats Onionpockets 09/12/06 12:07PM
  Re: does this sound like soft siezeRe: canadianTOMOS canadianTOMOS 09/12/06 12:11PM
  Re: does this sound like soft siezeRe: Jeff Jeff 09/12/06 12:24PM
  Re: does this sound like soft siezeRe: Don Ohio Don Ohio 09/12/06 12:50PM
  Re: does this sound like soft siezeRe: Jordan Caughey Jordan Caughey 09/12/06 04:10PM
  Soft seize? Clutch drumRe: Don Ohio Don Ohio 09/12/06 08:58PM
  Re: does this sound like soft siezeRe: mws mws 09/12/06 04:56PM
  Re: does this sound like soft siezeRe: mws mws 09/13/06 01:52AM
  Re: does this sound like soft siezeRe: Cleats Onionpockets Cleats Onionpockets 09/13/06 06:27PM
