nope, not a screws problem. if the float isn't pushing the pointy end of the valve up and stoping the flow you'll not get it with screws. Leave the bowl off and hook it to fuel and see if you can shut off the fuel supply with the needle valve. Is your float full of fuel? Is it set right to shut off when the fuel in the bowl gets to the proper level? bet not.\
