magnum forks maxi frame
Troy Brown /
Will it bolt up? or do I have to change the fork race?
Re: magnum forks maxi frame
I have maxi forks I do believe if you need a set
no the magnum forks will bolt right up i have had a set on my maxi for 4 years and never a problem and they ride sweet too lol
have fun
Troy Brown /
what bearings did you use? maxi, or magnum? Maxi bearings are in a cage. Magnum bearings are loose.
