jawa clutch cover
Is there a trick to removing the center nut and washer? The spare parts exploded view shows that it should just unscrew but I cant budge it. It's a wide, shallow nut. I dont want to strip it. Any ideas?
Re:Remove jawa clutch cover
Anybody? I assume it's similar on other mopeds as well. Is there an easy way to lock the fly wheel or whatever it is so I can get both hands on the ratchet to turn the nut that holds the clutch cover in place?
Re: jawa clutch cover
I use a strap wrench on the flywheel when taking the clutch nut off, if that helps. It keeps the motor from spinning.
Grey
Thanks, that does help.
