Re: Garelli - Project Moped - Help with the clutch
Chad h /
you should be able to adjust that either at the handle or at the clutch arm, there should be a little screw thing. i have mine set so i have to pull it all the way in, that way i wont wear it out by pressing the rubber too hard against the disc when starting it up. and when it does wear out a little, i'll adjust it tighter and get some more life out of it
-chad
