gas leaking outta the carb
Its a motobecane 7 with the stock carb - its not leaking outta the bowl or banjo - it s coming outta what i think is an overflow port for the bowl?? - it leaks when the bike is upright and the carb is mounted properly... WTF??
Re: gas leaking outta the carb
Ben Van Zoest /
ya float is stuck down, bounce the ped a bit maybe restores the closed position.
Nor Cal Mopeds /
I would adjust your float level
Leon Swarmer /
Check an make sure the float is operating the needle valve. Take it out and see if there is a bit of gunk preventing it from closing. You can test it with the bowl off and fuel going to the valve. it should stop the fuel if you hold it up.
Don't try this indoors or while playing with fire, too.
Leon
okay - i tried this again yesterday - i opened up the bowl and push the needle manually and blew into the banjo and it sealed?? - now... maybe i have the float upside down??... i'll check it today...
how do you adjust the float level?
