Re: slow puch maxi
Cleats Onionpockets /
Something's definatly up with your setup. I got your email, but didn't read this post before I replied. You have the potential to run mid thirties with that setup. Mine is set up with the stock cylinder, minus the ase and head gasket to increase compression, a bosch platinum spark plug, a stock 12mm carb, a 70 jet, a high flow air filter custom built, and the same techno Boss exhaust. I'm running 14-40 gearing, and I have no problem hitting between 30-33 on the flat. Granted, seeing as I'm a heavy guy (250 lbs on a good day) it takes a few moments to get up to speed, but it doesn't take forever, and I CANT hold mine back by just holding the seat with the throttle open. Something is screwy with your settings. The smaller jets will solve the richness problems, but if you want to add power you should probably come up with a better air filter. Autozone sells breathers for car transmissions that can be adapted for the purpose nicely.
  slow puch maxiTopic by: norm norm 08/18/06 08:31PM
  Re: slow puch maxiRe: Dan Dan 08/18/06 08:57PM
  Re: slow puch maxiRe: norm norm 08/18/06 10:57PM
  Re: slow puch maxiRe: Ben Van Zoest Ben Van Zoest 08/18/06 08:58PM
  Re: slow puch maxiRe: norm norm 08/18/06 11:01PM
  Re: slow puch maxiRe: Ben Van Zoest Ben Van Zoest 08/18/06 11:15PM
  Re: slow puch maxiRe: norm norm 08/18/06 11:42PM
  Re: slow puch maxiRe: seth seth 08/19/06 02:56AM
  Re: slow puch maxiRe: Nor Cal Mopeds Nor Cal Mopeds 08/19/06 04:29AM
  Re: slow puch maxiRe: Nor Cal Mopeds Nor Cal Mopeds 08/19/06 04:30AM
  Re: slow puch maxiRe: Dan Dan 08/19/06 03:40PM
  Re: slow puch maxiRe: Dan Dan 08/19/06 03:45PM
  Re: slow puch maxiRe: norm norm 08/19/06 03:57PM
  Re: slow puch maxiRe: Dan Dan 08/19/06 05:17PM
  Re: slow puch maxiRe: norm norm 08/20/06 02:33PM
  Re: slow puch maxiRe: Zane F Zane F 08/19/06 03:45PM
  Re: slow puch maxiRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 08/19/06 05:09PM
  Re: slow puch maxiRe: Brett Walker Brett Walker 08/20/06 03:17PM
  Re: slow puch maxiRe: norm norm 08/20/06 04:14PM
  Re: slow puch maxiRe: Brett Walker Brett Walker 08/20/06 05:04PM
  Re: slow puch maxiRe: norm norm 08/20/06 05:20PM
  Re: slow puch maxiRe: Ben Van Zoest Ben Van Zoest 08/20/06 06:06PM
  Re: slow puch maxiRe: norm norm 08/20/06 06:10PM
  Re: slow puch maxiRe: Brett Walker Brett Walker 08/20/06 08:38PM
  Re: slow puch maxiRe: Cleats Onionpockets Cleats Onionpockets 08/21/06 10:46AM
  Re: slow puch maxiRe: Tony Tony 08/21/06 01:51PM
