Re: slow puch maxi
Brett Walker /
you have way to many variables,
you need to put together the bike, as you want it, with one pipe, and one carb, all this switching around of carbs/jets/pipes/gearing is sort of like hearding cats
put the techno boss on there, make sure you have a good seal with the exhuast gasket, you can put your hand under there when the bikes runnings, and feel for an air leak, you should have none
test for compression to make sure you have no head/jug leaks, make sure all the top end gaskets are secure, i dont know what that kit should run, but probably somewhere around 150, at the least, i would imagine, anythying less than 120-130 could explain somethings
do you have a stock airboox? put that on to break in the kit, then get a bunch of jets, from low 60's to mid 70's, if not higher, and start with the largest and work your way down untill you have good throttle response, no bogging or four stroking or anything, you should be abble to open the throttle without any ill results
make sure your points are opened to .018, and your timing is set at least remotely right
keep your oil to gas ratio consistent, something like 40:1 for the kit, whats your ratio now?
if your plugs are looking oily and dark,, it could be because the needle setting is the richest, this effects the idle, and coiuld cause your plugs, although potentially looking lean at full throttle, to darken down at idle
i think a large part of your problem is jetting, 50 size jets seem way to small, and you could also have an air leak somewhere,
  slow puch maxiTopic by: norm norm 08/18/06 08:31PM
  Re: slow puch maxiRe: Dan Dan 08/18/06 08:57PM
  Re: slow puch maxiRe: norm norm 08/18/06 10:57PM
  Re: slow puch maxiRe: Ben Van Zoest Ben Van Zoest 08/18/06 08:58PM
  Re: slow puch maxiRe: norm norm 08/18/06 11:01PM
  Re: slow puch maxiRe: Ben Van Zoest Ben Van Zoest 08/18/06 11:15PM
  Re: slow puch maxiRe: norm norm 08/18/06 11:42PM
  Re: slow puch maxiRe: seth seth 08/19/06 02:56AM
  Re: slow puch maxiRe: Nor Cal Mopeds Nor Cal Mopeds 08/19/06 04:29AM
  Re: slow puch maxiRe: Nor Cal Mopeds Nor Cal Mopeds 08/19/06 04:30AM
  Re: slow puch maxiRe: Dan Dan 08/19/06 03:40PM
  Re: slow puch maxiRe: Dan Dan 08/19/06 03:45PM
  Re: slow puch maxiRe: norm norm 08/19/06 03:57PM
  Re: slow puch maxiRe: Dan Dan 08/19/06 05:17PM
  Re: slow puch maxiRe: norm norm 08/20/06 02:33PM
  Re: slow puch maxiRe: Zane F Zane F 08/19/06 03:45PM
  Re: slow puch maxiRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 08/19/06 05:09PM
  Re: slow puch maxiRe: Brett Walker Brett Walker 08/20/06 03:17PM
  Re: slow puch maxiRe: norm norm 08/20/06 04:14PM
  Re: slow puch maxiRe: Brett Walker Brett Walker 08/20/06 05:04PM
  Re: slow puch maxiRe: norm norm 08/20/06 05:20PM
  Re: slow puch maxiRe: Ben Van Zoest Ben Van Zoest 08/20/06 06:06PM
  Re: slow puch maxiRe: norm norm 08/20/06 06:10PM
  Re: slow puch maxiRe: Brett Walker Brett Walker 08/20/06 08:38PM
  Re: slow puch maxiRe: Cleats Onionpockets Cleats Onionpockets 08/21/06 10:46AM
  Re: slow puch maxiRe: Tony Tony 08/21/06 01:51PM
