Re: slow puch maxi
Nor Cal Mopeds /
heres some things you should check, make sure your piston is facing the wrong way, the arrow should point down, try filling the piston around and see if that helps. Another thing you should check is for a vacuum leak, when its running get some carb cleaner and spray it around all openings, around the carb, the intake manifold, the head/base of the cylinder, the exhausy port, and ESPECIALLY around the throat of the carb where it meets the intake mainfold, if you found a leak by your carb use some TFE teflon paste and put it on the inside by where the intake mainfild goes into, those bings get streched out really easy, and that is a common issue, and usually if it bogs its too lean and needs more fuel, so just for kicks try upjetting more than you would think.
  slow puch maxiTopic by: norm norm 08/18/06 08:31PM
  Re: slow puch maxiRe: Dan Dan 08/18/06 08:57PM
  Re: slow puch maxiRe: norm norm 08/18/06 10:57PM
  Re: slow puch maxiRe: Ben Van Zoest Ben Van Zoest 08/18/06 08:58PM
  Re: slow puch maxiRe: norm norm 08/18/06 11:01PM
  Re: slow puch maxiRe: Ben Van Zoest Ben Van Zoest 08/18/06 11:15PM
  Re: slow puch maxiRe: norm norm 08/18/06 11:42PM
  Re: slow puch maxiRe: seth seth 08/19/06 02:56AM
  Re: slow puch maxiRe: Nor Cal Mopeds Nor Cal Mopeds 08/19/06 04:29AM
  Re: slow puch maxiRe: Nor Cal Mopeds Nor Cal Mopeds 08/19/06 04:30AM
  Re: slow puch maxiRe: Dan Dan 08/19/06 03:40PM
  Re: slow puch maxiRe: Dan Dan 08/19/06 03:45PM
  Re: slow puch maxiRe: norm norm 08/19/06 03:57PM
  Re: slow puch maxiRe: Dan Dan 08/19/06 05:17PM
  Re: slow puch maxiRe: norm norm 08/20/06 02:33PM
  Re: slow puch maxiRe: Zane F Zane F 08/19/06 03:45PM
  Re: slow puch maxiRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 08/19/06 05:09PM
  Re: slow puch maxiRe: Brett Walker Brett Walker 08/20/06 03:17PM
  Re: slow puch maxiRe: norm norm 08/20/06 04:14PM
  Re: slow puch maxiRe: Brett Walker Brett Walker 08/20/06 05:04PM
  Re: slow puch maxiRe: norm norm 08/20/06 05:20PM
  Re: slow puch maxiRe: Ben Van Zoest Ben Van Zoest 08/20/06 06:06PM
  Re: slow puch maxiRe: norm norm 08/20/06 06:10PM
  Re: slow puch maxiRe: Brett Walker Brett Walker 08/20/06 08:38PM
  Re: slow puch maxiRe: Cleats Onionpockets Cleats Onionpockets 08/21/06 10:46AM
  Re: slow puch maxiRe: Tony Tony 08/21/06 01:51PM
