Re: dellorto blow test question
HuffyPuffy /
carb cleaner came out everywhere I sprayed it in, so I should be good there. I didn't try taking the float off. Isn't there some adjustment in that needle that the float pushes down--I didn't want to mess anything up as I've never had to remove a float before. Is there any trick to it?
