Re: dellorto blow test question
Silverfox Sullivan /
The hole is pretty damn small. That would make it hard to blow thru.
When you had it apart did you squirt carb cleaner thru it? And when you squirted it did it come out the other end?
With the float bowl off and the fuel line hooked up and the tap turned on, does the fuel flow out of the float jet?
